09-06-2020, 06:03 AM
(This post was last modified: 09-06-2020, 06:04 AM by ppppenguin.)
I have put a schematic for this set in the archive. It has been discussed recently in another forum. At the time of writing I believe this is the only published copy of the schematic. I also have a large dyeline print (between A1 and A2 size) but everything seems legible on the A3 copy that I scanned.
This compact set was used in schools. We had one for the hall's PA when I was at William Ellis School, Highgate, from 1967 to 1974.
It's mentioned with a photo on page 16 of this article, which is taken from the BVWS Bulletin: http://www.ferrographworld.com/pdf/A%20h...lletin.pdf
Quote:The compact all transistor 747 receiver amplifier from the mid 1960s was probably the last to be housed in the stout oak cabinet that became the trade mark of the earlier Clarke and Smith products. Many of these saw use in ILEA controlled schools and colleges throughout the London area. The unit is a fraction of the size of the earlier equipment and packs quite a punch in terms of facilities. The output is rated at 10 Watts, with provision for microphone, gram tape etc taken to P.O type sockets housed on the right of the unit. The VHF tuner is switch tuned for the reception of Light, Home and Third with user adjustment behind a concealed flap on the main control panel. The receiver actually has a conventional tuner covering 88-108 MHz which is only accessible when the receiver is completely removed from the cabinet, with a narrow band of VHF frequencies being adjustable in conjunction with the switch tuning. The loudspeaker output is on 100V line only with no provision for driving low impedance only speakers
