09-12-2019, 07:23 AM
(This post was last modified: 09-12-2019, 07:29 AM by Diabolical Artificer.)
I'm no expert on this Amie but have seen caps across SW's on several bits of gear and various schematics, but it can mean power is on with the power SW in the off position, a cap passes AC right? Therefore I think you have to get the value right or better use a snubber, IE a resistor and cap in series, again I'm no expert. This amp might have a neon indicator meaning if a cap or snubber is used it will stay lit, not ideal.
No idea Rob, I would try what you have, I have several pulled of old PSU's but from memory they are usually something like 47r and 10n, but I reckon for your amp a SW on the 0v tap of the secondary would be better. The tap and chassis ground are right near the mains primary voltage selector, so it's easily done.
Whilst on the subject of adding switches, I added a tremelo SW to mine so the tremelo can be kicked in without a FS. Again easily done without much hacking, having said that a 1/4" jack plug with tip and sleeve connected will do the same job, all your doing is grounding one valves cathode.
Andy.
Andy.
(Shorten the life of the switch), or is it just the best of a bad choice. I have seen those capacitors wired L to N that have puffed out what appears to be stinky steam?
