17-01-2019, 10:41 AM
(16-01-2019, 08:25 PM)Mark Hennessy Wrote: The wire used in loudspeakers to connect the cone to the terminals is called tinsel wire. That is braided, and obviously very flexible. I'm not sure it's the same type that we're talking about though - it looks like the strands are just regular (very fine) copper wire. And it's soldered. Next time I come across a damaged speaker, I'll take a closer look.
It's a very long time since I last looked at the wiring to the cone of a speaker (probably before you were born, Mark!) but it always looked to me like the braid from miniature single screened pick-up wire (as used for mono cartridges) with the centre, insulated conductor removed!
Very flexible and easy to solder - why would you need anything else?
