29-11-2018, 07:01 PM
My Weller TCP soldering station started blowing fuses. This went on for a while, but because of work commitments just kept plugging away with occasionally replacing the fuse. It eventually refused to work at all - instantly blowing fuses. Checked pin for pin on the 3-pin locking DIN plug and found they were all shorted. When I opened the handle the pictures show the horror story. This iron was 11 years old (bought new in 2007, confirmed by date codes). The wire insulation was crumbling - it fell off the wire with the slightest touch. Trying to strip back to find a good bit, I found that the wire insulation was crumbling along the entire length of the cable - there was no good bit!
I urgently suggest that anyone with a Weller TCP bought any time around then check the integrity of the insulation inside the handle. I've been using Weller soldering stations for forty-odd years, and I have never seen anything like this.
