29-06-2018, 05:19 AM
(This post was last modified: 29-06-2018, 05:22 AM by Diabolical Artificer.)
I'm winding another tfmr for an amp, again a toroid. I've stripped off the two 50v/5A secondaries and am winding a HT 280/310v @ 1A with several other wndg's for bias/CCS, etc. I'll need a center tapped 6.3v for elevated htr's for cathode followers, but this winding is proving problematic.
17 turns gives me 6.3v ish with a 4R7 load, this to power 3 off 6SN7's = 1.8A. With a tap on the ninth turn I get 3.6v and 3.2v, going back one turn, IE to the 8th, gives me the same voltages. no worries, I'll just use two 220r resistors to give me a virtual tap. I've had similar trouble with htr windings, it's tricky to get these low voltage high current wndg's to sit exactly at 6.3v with differing loads and as shown also tricky to get the tap exactly midway
To my question, how did they do it in the old days, is the fact that I'm using a toroid the cause of the problem? A E/I core must use more turns as the toroid core has a higher flux density, and thus easier to get the tap midway. Each turn on my toroid in 400mV, on a E/I core probably less.
I've wound the htr's wndg's first, right next to the primary for better regulation, and used thicker gauge wire than needed, not sure what more I can do.
Andy.
Andy.
