20-02-2018, 07:26 AM
"I ask again, how much does the Zout matter in this application?" AFAIK the higher Z out the better the frequency response, so it a matters a lot. We are trying to get better balance from the two OP's of a LTP, a more linear Op and more gain by using a CCS instead of a resistor. We want low DC Z and high AC Z.
Your right there are a lot of topologies Jeffrey, but I'm after something simple, high voltage and cheap that doesn't use exotic parts like Vref chips etc.
"Personally, it's far easier to measure Zout than to try to calculate it" The only way I know how to measure Z out is to use a variable R in parallel with the OP and twiddle until OP = 1/2. I suspect there's more to it than that. Using datasheet stated hFE is going to give you an approximate Z out yes? As the hFE of a Q as per datasheet is an approximation; could be lower than 100 or could be 250. As my circuits arn't critical and I'm still feeling my way an ish figure is good enough in most cases.
Compliance, heard of it, will do some reading up ont subject. How does one calculate it, or do you measure it?
Temp stability - the CCS is near valves, albeit somewhat shielded. Got you re using a 1N4148 as well as zener.
The ring of two sounds favourite Mark, I'll knock one up. The CCS I've been using has a 220r fixed R and either a 1k or 4k7 preset as Re. I've found that my calculated figures are often off. For instance say I've drawn a load line and chosen -8v as a good bias point but when the circuit is running while scoping the two OP's of an LTP I've found a better bias point by adjusting the CCS Re.
Thanks again for all your input, i'll do some building and testing and report back.
A.
A.
Yes, they have transconductance, but much less than a typical bipolar transistor. If you can live with the base current - and that's the way to regard base current (an inconvenience, rather than something that can be depended on) - then bipolar transistors will often do a better job. However, FETs are more marketable in some circles for whatever reason... And easier to understand than valves IMHO.
