09-01-2018, 02:22 AM
I'd like to use my TRIO SG-402 as a medium wave source for my reciever of year 1940. I'ts a long time since I have done anything similar. I don't know whether the SG-402 at hand works at all.
1) I would like to listen to the SG-402 to know that it works. My idea is to use a piezo speaker, a diode for demodulation, and a coupling condensator.
2) I would like to modulate the SG-402 from a plain 3,5 mm audio source. Should this work (given I do have a cable from twice Banana to 3,5 mm mono )
3) I'm really lost on how to bring the RF to my receiver. Preferable I would let hang a piece of wire from the output connector near the radio antenna. And ground is just open.
3a) I could connect the SG-402 terminals: Output and Ground, to the receivers terminals: Antenna and ground, directly except with a condensator to eliminate DC.
1a) I do not have a diode at hand, would a transistor from C to E do the job?
Tools I just have multimeters, digital and analog. Is it possible to measure signal output voltage, setting the SG-402 to range "A", as indicated in the manual on page 12? I do have a commercial AM/FM/Tape/CD receiver and a DE1102 receiver, that could receive what SG-402 emits.
Thank you
PS yes I do have the manual in print, probably the best copy in the western world, looking completely unread nevertheless the PDF from the archive would add And I do have the product catalog E-838-C 730820W.
Thank you
