13-07-2017, 11:35 AM
Found some approx 8mm diameter brass rod with 4BA tapped holes in each end. the original piece was about 113mm long so I've cut it to 109mm. Got to resolve how to fit it to the holes in brackets that operate the gang. I may have to cut it a bit shorter so I can insert some 4BA threaded rod and locknut it at each end. Would be much easier if I drilled a hole in the metalwork at each end of the tuner chassis but I'm reluctant to inflict this much violence on it.
