04-12-2016, 04:17 PM
(04-12-2016, 12:38 PM)Hartley118 Wrote: I recall the rough and ready but very speedy way that the cables were laid - by BT standards very flaky - using lots of flimsy looking American kit.
Flimsy? Although I've worked in the Cambridge headend on many occasions I've never seen their external plant but I've never seen a bit of 'flimsy' American kit anywhere!
The UK cable network is unusual in that the government granted licences on the basis of all cables being installed underground with the plant in roadside cabinets. Thus VM's network has cables in underground ducts in vast areas where BT are still using wooden poles and overhead wiring.
Elsewhere, equipment does not have the luxury of the protection of a street cabinet, being virtually all mounted overhead and exposed to the elements. Flimsy kit does not survive in such conditions! This applies equally to Europe and the US and, I suppose, everywhere else that has cable TV.
In the US, virtually all kit is mounted on utility poles or catenary wires between them - particularly taps and splitters, although amplifier casings usually also have provision for wire mounting. Obviously, all kit has to be weatherproof and one of the first things I noticed about the particularly large Scientific Atlanta amplifiers I first worked on was the hiss of escaping air you often heard when you unscrewed the cap which gave access to the internal test points - particularly so if the case had last been opened in very cold conditions as the trapped air could expand quite a lot as the amplifier reached normal operating temperature.
One aspect of the Cambridge build that caught us out was the unusual 19" cabinets - there was no obvious way of mounting shelves in them! As the routers we were installing were extremely heavy, they couldn't just rely on front mounting to the normal cage nuts - even if you could have held the weight steady enough to get the bolts in in the first place!
When we asked the local staff what the secret was they provided some small but heavy duty brackets bent in such a way that the fitted slots in the side of the cabinet. Four of these were plenty strong enough to support the routers without any additional support.
Another Cambridge oddity was the use of plastic street cabinets! I have since seen a few of the smaller size plastic tap cabinets in the Lincoln area so Diamond Cable also used them.
![[Image: t006_r07209_v3.jpg]](http://www.commscope.com/catalog/imagesCache/0000050/t006_r07209_v3.jpg)
