25-11-2016, 05:35 PM
(This post was last modified: 25-11-2016, 05:37 PM by Geordie McBoyne.)
I've installed a Garrard SP25 Mark 2 record deck in the RGD 1046 radiogram. The pick-up is a Shure M75 which suggests a low output, let's say 20mV.
So there is a requirement for a pre-amplifier, I've got a few circuits to hand and it seems the valve of choice is an ECC83 arranged as a two stage amplifier.
RIAA equalising included in the circuit for magnetic pick-up. But what about using a pentode valve instead? We know the noise generated by such a valves will be higher than that of triodes, that's the way it is with multi electrode valves. However, more gain can be realised by the pentode and as the valve is driven from a fairly low source impedance, this fact alone might make the pentode valve a viable choice. Your views on this subject?
Geordie McBoyne.
Geordie McBoyne.
