14-09-2016, 07:44 AM
Hi Ken,
Yes, there is a 20 minute edit window. That's pretty standard across forums. When Golborne first started, we ran without this restriction, and found that it occasionally caused problems.
This is an example. If you amend the original post, some of the subsequent posts that question the valve type will make no sense!
Naturally, I could edit your review, and am very happy to do so. So once we're 100% sure what this valve is, I'll update your review, but will also need to edit or delete the subsequent posts that question the valve type.
Thanks for the review, BTW. It's an interesting looking bit of kit. Shame there's no schematic. I'd be interested to know why they're combining 5532s - one of the best, lowest distortion audio op-amps ever produced - with valves. Often the valves are just followers - sometimes they're not even in the signal path! We don't just listen with our ears
Mark
Mark
