10-05-2016, 07:20 PM
I think that nowadays, those who have a laser printer tend to use the ‘iron-on’ technique using scrap golly magazine paper and seem to get acceptable results. But I’m set in my ways and for maybe 30 years or so, have used a home-made UV exposure box. For anyone who may wish to consider making their own UV box, there’s a well made video at the link below on how to make an excellent box from a Maplin insect killer at this link:
https://www.youtube.com/watch?v=REnWbrRgZOQ
I thought £15.00 from Maplin was too good to be true - unfortunately the UK insect killer has been discontinued, as have the tubes:
http://www.maplin.co.uk/p/20w-high-power...ller-n98gr
http://www.maplin.co.uk/p/10w-uv-replace...lers-n47ja
However, there's a firm that sells liquidated discontinued stock, and they have the Maplin remaindered stock of the insect killer for £21.50 post free. You couldn't buy the tubes for that!
http://www.cqout.com/item.asp?id=18665504&gclid=CMKvpqSOqswCFUefGwodbeAG9A
That makes an excellent light box at a fraction of the cost of very basic commercial ones.
I long since gave up buying pre-sensitised boards, both on the grounds of cost, and of ending up with lots of useless off-cuts. I usually use PRP positive photo-resist UV aerosol spray lacquer for making PCBs. Not cheap at £15.00 a can, though it goes quite a long way:
http://www.maplin.co.uk/p/positive-photo-resist-n17kh
I came across an alternative method of pcb production, so I thought I’d give it a go.
The video at the link below shows how it’s used, but basically, it’s a UV sensitised film from which a protective film is first removed, then the film is applied to the PCB laminate and passed through a document laminator two or three times to ensure that the film adheres to the PCB. Then a protective film is removed and the artwork acetate placed on the laminate to be exposed in the UV box in the normal manner. This method has the benefit of not having to spray lacquer on the board in a dust-free area (no such thing really in a home environment), and waiting 24 hours or so for the lacquer to dry and harden off. (I put my sprayed boards in a desk drawer overnight).
One important difference with the film technique is that the artwork must be a negative – not positive. This is easily accomplished in MS ‘PAINT’ by selecting the image, right clicking on it and in the drop down menu, clicking on ‘invert colour’ then saving, and printing the acetate. In the video, the text refers to printing the artwork onto ‘vegetal paper’ which is just another term for tracing paper. Personally, for artwork I use ‘micro-porous film’ from Crafty Computer Paper and based on a ‘Big Clive’ video which Joe put me onto, I’ve managed to fool my Epson ink jet printer into printing onto acetate, which ordinarily, Epsons won’t do in a quality that comes close to what’s needed for PCB production. I now get completely opaque high quality images.
Here’s the photo-sensitive film technique process:
https://www.youtube.com/watch?v=2hQfGtSFe_0
Another video here:
https://www.youtube.com/watch?annotation_id=annotation_2190592885&feature=iv&src_vid=Vj_cdBZO1Tk&v=cRCFGZxmob0
This is the film that’s used, (30cms x 5M for a little over a fiver sounds good to me):
http://www.ebay.co.uk/itm/30cm-x-5M-Phot...Sw9N1VyG7s
The sodium carbonate (AKA ‘soda ash’, ‘isinglass’), developer is cheap enough too, at £5.49 per KG and only a few grams are needed for each board:
http://www.ebay.co.uk/itm/300980297463
I’m just waiting for the film to arrive on a slow boat from China and when I’ve given it a go, I’ll update the thread.
I'm content with the quality of the PCBs I make, (see below for a couple of recent ones), but on the face of things, using the film looks like a bit less hassle than UV spray lacquer.
Hope that’s of interest to someone.
Another video here:
Meanwhile, I'll carry on enjoying life, as indeed I do!
