14-02-2016, 10:17 PM
An interesting thing that can be worth a try, is to use a 1 metre tuned 6 turn loop with single turn secondary is with a RF low to high impedance matching transformer on the single turn.
From the high impedance secondary add an OA91 and set of high impedance phones, one instant selective crystal set that can happily pull in reasonable strength stations.
This works far better than adding a detector and phones to the tuned 6 turns, the single turn will struggle to give 200mv signal to detect. The addition of the transformer will give higher voltage to detect, go too high and the frame will be loaded excessively and become less selective and actually give less audio.
Where do you get the ferrite rings Trevor?
