22-12-2015, 10:42 AM
I'm following your other Thread with interest. I briefly thought it might be a Signal Generator or a Wave Meter but probably not.
Alan
Alan
An interesting old Coil
Alan
22-12-2015, 10:57 AM
(22-12-2015, 10:42 AM)AlanBeckett Wrote: I'm following your other Thread with interest. I briefly thought it might be a Signal Generator or a Wave Meter but probably not. Cheers Alan, I'm following the same on your coils thread for sure, you're doing a good job with the research/ID, pictures, diagrams and descriptions, all very clear and to the point, plus hopefully if the internet lasts it will be an historical record covering a particular aspect of early vintage receivers that very little seems to be known about these days. Lawrence.
22-12-2015, 03:20 PM
Thanks Lawrence. My guess wasn't too bad apart from the 'Other' Front Terminal which I thought was an alternative Aerial but was actually the Earth.
What a Charles not thinking of that ![]() Alan
24-12-2015, 07:39 PM
Last lap before Christmas?
I've done a bit more investigations and as far as I can tell it looks like this:- A few Comments:- The Black 'Spots' on the Switches represent the Insulated Contacts. The Switches have no Detents. You have to rely on the Markings and the 'Feel'. The only Switch Connection that I can positively Identify is the AERIAL Terminal to the Wiper of the APERIODIC SWITCH. Seems logical. I still don't know what AG means. The Shaft of the WAVE CHANGE SWITCH is extended at the back. Perhaps there's a Brother to this Coil so you could add an rf Stage. As far as I can tell the ANODE Terminal isn't directly connected to the REACTION FIXED Terminal. There's a small Resistance but no measurable Inductance. The connecting Wires disappear into the Coils so perhaps the Reaction Winding is split. Without disconnecting Wires, which I'm reluctant to do, I fear there's no way of telling. So, I suspect the only sensible thing thing to do is believe the Connections as written. Alan
28-12-2015, 12:09 PM
(21-12-2015, 10:03 PM)AlanBeckett Wrote: And finally(?) for this year ..... Alan, Ref. AG position: Antenna to Grid? Lawrence.
28-12-2015, 01:30 PM
That's a good Theory, I like it
![]() As before I'm not sure how to prove or disprove it without disconnecting. I'll have a think. Alan
05-01-2016, 06:15 PM
Just a visual reference from an old listing (British General):
http://www.ebay.co.uk/itm/Vintage-1911-B...SwwbdWJTYu&nma=true&si=P9llJOK%252BabsRg0okHBxZU1tF0zE%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 Lawrence.
05-01-2016, 08:29 PM
Poor old Soul
![]() There's a good picture of the way the Switch works on the Screw Heads. It's just as well I didn't see that at the time. Alan
06-01-2016, 09:43 AM
Alan, I came across at least one other completed listing on Ebay showing British General coils "similar" to the one shown in post#117, they were undamaged.
You might have already come across them but I'll post them up anyways. http://www.ebay.co.uk/itm/Vintage-amateu...SwT4lWSblM&nma=true&si=P9llJOK%252BabsRg0okHBxZU1tF0zE%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 http://www.ebay.co.uk/itm/Vintage-Radio-...SwAKxWYy3l&nma=true&si=P9llJOK%252BabsRg0okHBxZU1tF0zE%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 Lawrence. |
