30-11-2015, 05:04 PM
NM, something would get hot, resistor/rectifier/mains transformer if fitted, possibly a fuse would blow if the radio had one, if no fuse then it would usually mean permanent component damage.
Most of the hard wired radio chassis had the wires wrapped at least half a turn around the connection points, dry joints were the most common problem, caused by poor soldering techniques including oxidization of component leads and connection points etc prior to soldering, it got worse when printed circuit boards were introduced.
