11-08-2015, 04:35 PM
There is something in my HAM book that sadly isn't clarified by actual examples. It was talking about how to total up inductive or capacitive reactances either in series or in parallel. The way to total capacitor reactances in series or just coils in series was simple to explain. It's just the same as resistors so there was no problem.
Where it got vague was the case when there is a series of capacitors and coils. In that case, the XC is said to be negative and the XL positive. If you were making a total for, say, resistors in parallel you'd just multiply the two values to get one sum, add the two values to get another sum and then divide the latter into the former for the overall total.
As it gave no actual example, I can only assume you're supposed to subtract the XC negative from XL positive. It's because the XL voltage leads the current and the XC current leads the voltage so any calculation has to take phase into account. Actually the sum is obviously very simple if you are already given values to work with in Ohms. I mean, if you have, say, 10 Ohms XL and 6 Ohms XC in parallel, do you just subtract? Sadly the book doesn't fully explain as I can always work it out if there's a working example.
