29-07-2015, 04:41 PM
Ok...confession time, I've not built a SS power supply for many moons, having said that the LM338 is rated at 5 amps max, various articles on the web suggest that you can vary it's output from 1.2 volts up to 30 odd volts, most valve heaters run at under 1amp (there are exceptions) 30 volts DC input to the regulator (or there about)would give a variable DC output to cover most of the more common type of valve heaters.
You could also use the 30 volts output from the transformer to supply -ve grid bias via a rectifier, filter and pot + a voltmeter.
If that would work ok then it might be better to construct it as a separate bench supply, that way it's easy to use it for other jobs, others will probably know more about SS regulators than I, Mark H springs to mind.
