23-05-2015, 10:56 AM
Damage to the top has been repaired and the top is now re-finished. The weather is not good for spraying so I ended up applying about 5 coats of shellac by hand then sanding up through the grits to a final wet sand with 1200 grit followed by three grades of polishing compound.
Not sure what I'll do for the sides since I can't re-produce the original colour. Since it looks black from a distance I'll probably go with that.
Cheers, John
Cheers, John
