21-04-2011, 01:37 PM
Joe,
I have to say that it's a test I've never tried. If you suspect a H-K leak then the usual approach is substitution. I fear that the best bet may well be to start again with a logical approach. If you inject a signal into the EL84 G1 with the other valves pulled what happens? Also, I'm assuming that the Volume Control is OK and the bottom end is properly returned to chassis.
Do you favour cream, ice cream or custard with your crumble?
Alan
Alan
