18-04-2011, 07:36 PM
There's a good inch of clearance between the panel lamp brackets, as circled by Rob T, and it sounds bad with the chassis pulled out to the limit of it's wires.
It could be something nasty under the dust cap, though that itself isn't loose. I'll investigate further tomorrow as by back is already very cross with me for bending over it so long earlier.
By the way, the circuit board IS bent and appears to be by design. It's held by screws at either end and has a guide on the chassis in the middle.
