16-01-2013, 01:44 PM
At our woodturning club, of which I'm secretary, we use a PA system - a Chiayo 'Focus 500' with a remote UHF radio mic. Quite a commonplace system and not a cheap affair at about £500. (It was paid for by Awards for All as part of a £3,500 successful bid I submitted for lottery funding five years ago so is well out of warranty). It has a built in 12V SLA battery to make it truly portable, and an external PSU/Charger. We only use it once a month so the battery is permanently run down, but when we plug in the PSU it works happily from that. (The Power supply is 240V AC,1.5A / 15V DC,4.3A output).
http://www.aandcaudio.co.uk/chiayo-focus...em-p131490
A new battery is £48 inc VAT – not that we need one, and if we did, no doubt a cheaper source could be found.
http://www.aandcaudio.co.uk/battery-for-...em-p271541
Last night, there was a pop when I switched it on, and on checking the switched mode PSU it had no output. I stripped it this morning and found a dry joint on the PCB where a 120uF 400V electrolytic cap was connected. It looks like it's been arcing at the dry joint as there are signs of overheating on the PCB. Unsurprisingly, the el cap has an infinite ESR and reads 47pF on a capacitance meter, so is obviously duff. I've ordered a replacement cap (off e-bay - where else?), which should be here tomorrow.
I know little about switched mode PSUs. I checked for continuity at the mains input socket, and it's open circuit. On a conventional PSU that would suggest that the primary winding on the mains transformer was open circuit. However, on an SMPSU it doesn't have a mains transformer as such - it does have a couple of inductors wound from quite heavy gauge wire - I'd guess about 24 - 26 SWG, which look OK. The question I'm asking is would we expect to see an open circuit at the input of an SMPSU, or an Ohmic reading? It's quite a complex PCB with many components including surface mount, so really, if this cap doesn't sure it, it's beyond economic repair.
I dare say I could source a new PSU, but if I can repair this one, I'd prefer to. I'll soon find out when I replace the cap - it will either work or it won't! Hence, my question is out of curiosity rather than desperation. Any thoughts anyone please?
