04-11-2012, 09:45 AM
Hi Gary, I have never come across staggered IF's for standard AM either, but I thought I would ask to make sure. Removing slugs can be a pain as you know but in the main they normally give up and come out or at least loosen up enough for alignment purposes. My own experiences tally up with yours, the slot has to be cleaned out real good and the tool that is used to fit in the slot needs to be an exact fit to the profile of the slot, I find that initially screwing them in rather than trying to unscrew them is a good option, if all goes well it will reveal a turn or two of clean thread in the former then you can follow and clean up from that with an angled pointed tool to scrape the gunked up part of the thread out. I did an R1155 a while back, I did all the slugs in rf/osc coils but one had snapped in one of the IF's, I swept the generator through it and it was about 500c/s out so I realigned the other IF's and the BFO to that with good results.
I remember doing loads of tv's in the 60's the hex slug ruled then, they really were a pain, a lot of manufactures used polystyrtene formers which due to the heat in the tv tended to shrink on the slug, the only option was to break or drill them out.
