25-10-2012, 06:07 PM
i used to drive a pair of mission 780 from a beam echo advantic valve amp .the output of this amp was app 8.5 watts.
in a 13x12 foot room you would not want to turn the volume full up.
the trouble is that you want massive power (for a valve amp ) and high quality . to get the high quality the output stage needs to baised towards class A this means big high quality output transformers.
another idea you may want to investigate is say a 30 watt valve amp and high efficency (102 db/watt ) speakers.
or how about bi amp say a high quality valve amp for mid and trebble and high power solid state for bass.
just ideas
rob t
just ideas
rob t
