04-05-2026, 11:52 AM
Fixing Hackers is fun but why did they use such odd values of electrolytic capacitors?
Example, the 205 amplifier pcb uses 80uf (2 in parallel), 6.4uf, 40uf and 400uf. None of these are present day standard values.
Is it a supply situation or deliberate act to use unpopular values?
I substitute the closest values from stock, 100uf, 10uf, 47uf and 470uf. With the wider tolerances these seem close enough.
Boater Sam.
