22-12-2020, 11:05 PM
Yes indeed.
I always wonder how long these sets have been unused.
The interesting thing with this set is the good condition of the main smoothing capacitors, bang on capacity and good ESR.
The warm up time is very long. Monitoring the voltage on the CRT heaters is odd. They rise to 3.1v in around a minute then they slowly rise to 3.8v then drop back to 3.5v then slowly rise to 5.6v maximum. There is a raster at 4v and the picture shows around 4.8v. Warm up time to 5.6v is nearly 5 minutes. I suspect the thermistor is the problem so if I have one I'll replace it and see.
5.6v on 6.3v heaters is bit too low, all the valves look dull, I've not checked the full chains voltage or current as of yet.
