11-05-2011, 12:10 PM
I'm aware of the usual advice to fit valve radios with 1A fuses in the plug-head and that this is a higher rating than is ideal but is the smallest available.
I have been considering fitting internal fuses to my sets, assuming I can ever declare one finished, and besides the current rating was wondering what the best blowing character would be: fast, normal or slow. Also, would there be any point in putting ones on the HT and LT secondaries to protect those windings?
- Joe
- Joe
) then the fuse can be safely removed. However, if the fuse and switch are transposed, there is a risk of electric shock when the fuse (even if O/C) is removed. The counter arguement runs that that method fails to protect the switch, since the fuse comes after it. My preferred method seems to be favoured by U.K. designers; the latter by those in the U.S.A. I have never had a mains switch explode under a fault condition (this is the usual claim against my method) with my preferred method; obviously, the switch must be adequately rated for the set in question.
I was thrown back across the room, banged my head on something hard and was laid out unconscious for a few minutes (I think). Fortunately, the Eddystone (& I) survived
. Soon after, I added a paxolin tube to the valve base to prevent a repetition of that accident. And I've been very conscious (pun not intended) of such a hazard ever since - especially when I look at the scar on my finger - which remains there to this day, 47 years later.
