11-08-2017, 09:56 AM
(This post was last modified: 11-08-2017, 10:01 AM by Geordie McBoyne.)
Last week I bought this early transistor radio from from an Ebay seller. The set is a later development of the 1957 Pye P123BQ. It differs from the early production models in having full coverage of the long waveband, the earlier models had only one pre-set station on LW. The other difference as far as this set is concerned is the type of transistors employed, the Mullard OC44 range instead of the Newmarket types of the V6/R4 series. The IF is 315Kc/s.
The cabinet needs attention, the red material around the sides and top of the case has completely worn off and so has the lacquer on the brass trim.
The P123BQ was the follow on model from the 1956 Pam 710.
Geordie McBoyne.
Geordie McBoyne.
