11-04-2017, 08:12 AM
I'm putting together an amplifier using all TV valves.
Push pull output with PL36s, got loads of them.
The question is, do the primary windings of the transformer get wound on the bobbin/s in the same direction relative to the core or are they wound opposite ways, if so why?
I have never wound a push pull transformer hence the query.
To reduce the capacitance this will be wound on 2 bobbins, half the primary and half the secondary on each bobbin with the windings cross connected in series. I assume I connect end of one to start of the other?
Been reading books on how to do it but can't find answers to these questions.
Boater Sam.
