30-07-2022, 02:04 PM
Oh and compared to ANY valve the Rod Pentodes have nearly non-existent internal shields. The cans or perforations you see on most valves are screens to replace the outer conductive paint, not the anodes. The screening is just some support rods connected to f- or s or g3. The 1j37b has the fewest screen rods. I make a springy holder from cut up coffee tin or similar as the rod tubes are also sensitive to magnetic fields.
