09-09-2020, 09:44 AM
Absolutely
Electric car climate control
09-09-2020, 09:57 AM
(09-09-2020, 09:08 AM)Murphyv310 Wrote: Can you imagine driving to work, plugging your EV in and there is a major issue with the grid and your EV is then powering the grid. You then jump in the car and see you have insufficient range to get home. I somehow think that won't please you after a hard day's graft. In any sensible V2G scheme you set the rules for how you want your car battery to be used. So if you need X amount of charge at work to get you home then you simply set up a rule to that effect. V2G is in its infancy and I'm sure there will be mistakes along the route to maturity but ultimately this is not conceptually different to a gas fired power station saying on what terms it will generate as happens on today's grid.
| 3 Guest(s) |
