01-04-2011, 08:45 PM
I intend doing the minimum of work on this set. Looking at R&TVS It looks like I will have to change "them" caps c67 and c68 they look like electrolytic but am sure they are not, the red ends are bulging. I intend using the yellow BVWS .047 1000vdc. The tone correction caps c71,c72 are .002 300vac what value is best for today's listening? I will also have to change the 2 mains input caps, could I try it with them out of circuit?. I wounder if the speaker will take the full 7 watts! after nearly 50years, maybe better not try. If I have got anything wrong I would like to know before I start. Thank you, John.
