30-05-2018, 09:07 PM
Having recently corrected a wiring fault and re-soldered some poor earth connections on an electric guitar, it's owner tells me that some hum is present, when the guitar is connected to his amplifier. This wasn't present at an audible level when I plugged it into a small mono test amplifier. Over recent years I've repaired several guitars which have had various faults in the wiring to the control panels, all of which make use of the pot. bodies as earthing points, and I've suggested that things might be better if the controls were mounted on a suitable metal panel, and various earth leads, including the screens of pickup leads connected, as far as practicable, to one point, the metal pot. bodies being earthed via their fixing nuts. Has anyone wired guitar controls in this way, and /or found a way to eliminate or reduce hum, which, IMHO, might be caused by earth loops. I didn't take any pictures of the guitar in question, so cannot post illustrations. (Apologies for that omission!)
