10-06-2026, 04:11 PM
(This post was last modified: 10-06-2026, 04:14 PM by ppppenguin.)
If I didn't need anything special for a 'scope I would probably go for one of the dual channel Hamegs. Simple and reliable. A Tek 2225 would also be fine, as would one of the lower end Philips analogue instruments. I'm sure there are others. Iwatsu? Avoid anything Advance/Gould due to iffy EHT section. Anything old and valve is for testgear enthusiasts only. Even the Telequipment D66 etc which I lusted after in my youth aren't exactly reliable. Nor are the otherwise quite nice D75 and D83.
My RIgol 1054Z does a pretty good job as a digital scope but still too many artefacts for my liking. I don't use it enough to find it intuitive to drive. There are plenty of usable digital scopes at the sub £200 level.
And always have at least two 'scopes so you can use one to fix the other
