03-12-2016, 01:15 PM
As I would expect component numbers to be allocated in a logical order it seems more likely that R24 existed in earlier versions of the design but was later eliminated.
If the PCB wasn't redrawn to suit, a wire link should be present if you've correctly determined its function ...
