01-02-2014, 04:22 PM
Hello, I managed to pick this up from Ebay this week, and being the only bidder I managed to secure it for only 10 beer tokens, complete with stand, manual and remote.
The seller described it as thus :
Now I have come across this problem before so after getting it home, I decided to whip off the back to investigate, as prior to bidding I did some research and sure enough it contained a Vestel 17PW20-32 pcb which I have worked on a few times before, and is quite common in a lot of plasma and lcd tv sets.
So on visual inspection, the usual suspect capacitors stood out, sitting there like little balloons in the 3.3 volt standby supply line, now if high esr or low voltage drags the supply below 2.3 volts, the board fails a self test I believe, which causes shutdown or in this case to stay at standby.
A little trick I have learnt is to give the caps a blast of high heat from a hairdryer for a couple of minutes, and this sometimes will enable the tv to fire up to confirm the problem, which was the result so confirming the problem.
old caps in situ :
So after a trip to maplins, I replaced the three leaky caps, substituting 6V3 for 16V as they were the nearest rating they had in stock, total cost £2.68.
Refitted the panel back into the tv, powered up, pressed standby and the tv burst into life, with a great picture and sound from the skybox via HDMI.
Now over the last couple of years I have equipped the house with an Hitachi 42in plasma, an acura 37in lcd, a bush 28in lcd (which was gifted to me, going wrong just out of guarantee) along with this recent purchase, all for under a hundred pounds,
including repairs
I dont need anymore tv's, but if the chance arises again, it will be hard to resist.
Quote:just wouldn't turn on one day lights up in standby when you click power nothing and you have to pull the cable out to reset the standby
old caps in situ :
including repairs
