16-04-2017, 01:01 PM
I bought one of these radios at a boot sale on Saturday, you can see one like it in the radio museum. KB KR019
It looks just like the one in the museum. The case is some kind of thick card covered covered in plastic film. Where the back hinges open the plastic has cracked as in all these types of case.
There has been some obvious tampering with the trimmers and wiring. One of the IF slugs was broken, which I repaired by dismantling the can and replacing it with a slug from an IF transformer I got from Pamphonica.
2 resistors had been cut. One leg of R14 in the discrimninator circuit and another mystery 150k resistor fitted across L8.
There are holes and pads in the printed circuit board for the 150k resistor, but it is not shown in the schematic and not present in an identical Regentone TR419 that I happen to have.
There is quite a lot of hiss as soon as the set is switched on, coming from the audio section after the volume control.
MW was receiving something, but not very well, LW was just picking up R4, and FM was dead.
I have started to check the voltages and got as far as TX8 where the collector voltage was almost the same as the emitter voltage. On checking the resistor R36 I found it to be marked as a 150k one. Then I found that R37 was a 10k one. so I have swapped these round using, what seemed to me as micro surgery.
What do you think, do you feel the radio would have worked on FM at all with R36 & R37 fitted incorrectly in the factory.
I have no idea what TX7 & TX8 are there for, what function do they serve in the circuit.
Mike
Mike
