On the topic of reforming electrolytic capacitors, I built the capacitor tester/reformer unit that featured in the winter 2008 issue of the BVWS Bulletin. The article had first appeared in Radio Bygones June/July 2008, which prompted me to build one. Several components wern’t easy to find, notably the LCD panel meter, analogue panel meter, IRFBE20PBF transistor, and the two 6V transformers. If anyone contemplated building that one, following info might help anyone else faced with the same problems:
At October 2013, the 500V LCD Digital Volt Panel Meter 3 1/2 DC is available for £4.69 with free delivery, and can be viewed and ordered online at the link below from:
http://cgi.ebay.co.uk/3-1-2-Blue-LCD-Dig...uipment_ET&hash=item230ffe6083
As with most of the digital meters of offer, the power circuit of the meter must not share ground of the circuit that is being measured, but that wasn't an issue for me - I used the spare winding on one of the mains transformers, though if anyone looks at the circuit in RB or the BVWS Bulletin, it shows a common ground. Anyone who builds this project will need to consult the actual meter instructions. I've attached the original RB circuit (same in the BVWS Bulletin) corrected by me with the common ground connection removed, and also a copy of the note and diagram which came with my meter showing how to correctly wire it.
As a cautionary tale, when they say “500V” that’s what they mean. I squirted 535V into mine and they don’t like it up ‘em! My fault entirely, through not having the voltage control backed off. The meter expired and I had to get a replacement, which arrived just as quickly as the first one, but I treated it with more respect.
As at October 2013, The IRFBE20PBF MOSFET is available and in stock from RS for 67p at this link: http://uk.rs-online.com/web/p/mosfet-tra...s/5429535/
Some constructors might wish to cull a transformer from a scrap set, and the article explains that option, but I used two new 6 Volt transformers coupled back to back (that is with the secondaries coupled together, so you put 240V into one transformer, and get 240V out of the other. A doubler circuit uplifts that to 500V (adjustable). I obtained the transformers from ESR Electronics –again, a most helpful firm I’ve used many times over the years: Side Tag Transformer 0 - 6, 0 - 6V (2 x 1A) Order Code 301-045 £8.88 plus VAT + P&P.
View the transformer here:
http://www.esr.co.uk/electronics/product...ormers.htm
ESR can also supply the analogue 0 - 10mA Panel Meter, Order Code 124-124 at a keen price of £4.26 each + VAT. View the meter here:
http://www.esr.co.uk/electronics/product...tequip.htm
ESR's website is here, from whence you can read or Download the latest version of their Catalogue, which features over 500 Semiconductors, Resistors, Capacitors and Diodes:
I have no connection with any of these suppliers, other than as a satisfied customer. I hope this info might assist any forum members who might otherwise be discouraged from building this project due to problems sourcing these components.
I’ve attached a couple of pics showing the outside and inside of my reformer.
Hope that's of interest to someone.
(Updated October 29 2013)
David
David
