06-04-2016, 09:37 PM
Hello,
I've just come across an old HCD Research oscillator - a HCD81 running at 10MHz.
As you'll see from the picture, pretty much everything I need to know is on the label. But with one exception - how to use the Vf input. I presume it'll be a preset between 5V and GND, perhaps with a series resistor, but I'd like confirmation first as it would be a shame to damage it.
The unit works quite well, but the output frequency is a few hundred Hz away from 10MHz, and it doesn't quite settle down - well, not in the 30 or so minutes I've run it for. The lash-up on the bench probably didn't help - just test leads, no decoupling or anything. Leaving Vf open-circuit probably didn't help.
I do have another one of these, running at 8.86MHz (guess where that came from
). That one has a 9V heater voltage - I guess these things were pretty customisable. As I'll never use it, I could open it up and reverse-engineer it, but I'm hoping that someone like Jeffrey will have used these in the past and might still have some data.
Thanks in advance,
Mark
). That one has a 9V heater voltage - I guess these things were pretty customisable. As I'll never use it, I could open it up and reverse-engineer it, but I'm hoping that someone like Jeffrey will have used these in the past and might still have some data.Thanks in advance,
Mark
