10-02-2016, 06:05 PM
Hi.
Well this is not so much a home-brew item but a home-brew solution.
Way back in 2006 I bought a Wellbrook ALA1530 Loop aerial. The loop was a godsend in my noisy area, I could receive stations that it was impossible to hear on a long wire or active rod aerial (Sony AN1)
My only gripe was the output wasn't that high, a low performance radio wasn't ideal, Wellbrook though redesigned the amp later on for higher output.
I got about 5 years out out of the loop then it went intermittent with it cutting off if it was breezy.
I discovered that the amp unit that is a plastic unit was cracked and this had compromised the loop that is a composition of alloy & ferrite, the ferrite was cracked too.
The loop was then withdrawn from use.
I then discovered this circuit on the net.
I then added this to the loop in an external box. It worked very well, far better than the ALA1530 ever did, with the exception it ran out of steam quite early, above 15Mhz it went deaf.
I had troubles though with the original amps mounting and the whole thing was pensioned off.
Today though I have rebuilt the whole thing. I have built a second amp using 2N2222A transistors rather than the BC109's I used previously, I also used a different ferrite ring for the coupling transformer and also used a waterproof box to house the amp and feed in the ends of the loop.
The loop has been secured with jubilee clips and epoxy resin and once completed the box will be epoxy sealed.
So far a quick test has resulted in the best performance so far.
Pictures to come
Pictures to come
Cheers.
Trevor
Trevor
