17-01-2016, 07:39 PM
I'm still having no luck trawling through the net for any infomation about the coil and tuning assemblies employed in the Smokers Cabinet Marconi Model RB12. Similar models are the V4 and VB4.
These receivers employ a spade type of tuning system
I Have found the pictures of the internals of the later model VB4 showing the circular aerial and detector tuning assemblies.
Evidently the spade tuning system was attributed to Marconi Man C. S. Franklin.
Some cabinet construction details are different, for example, my set has a box for the 40 volt battery. The set shown in the attachment has a retaining bar to hold the battery in position. Seen at the left rear view of the VB4 internals.
What is known the coils are of the "pancake" type similar to those in the V2. A sliding copper spade does the tuning in the V2 and it is known there is something similar in the RB12, V4 and VB4. There must be some type of gearing to move the spades inside the RB12 tuners.
Also the flat coils must be quite compact considering there are two separate assemblies for short and long wavebands.
Geordie McBoyne.
Geordie McBoyne.
