08-09-2015, 10:01 AM
Hi.
I was given a chassis from a late 40's Pye 65A table radio.
It was covered in the usual corrosion around the battery aperture and was quite grubby.
I decided to just power the chassis up with 2v & 120v which is the recommended supplies.
I connected an aerial and "yes" off it went perfect
Since then I've de-rusted the bad section cleaned the chassis and changed the wax caps.
Now all I need is a set of knobs, dial glass and a cabinet!
