22-08-2015, 12:14 AM
I have begun doing one of these ex Royal Navy signal generators. The build quality is very over engineered by today's standard but for us fans of well engineered stuff it is a fantastic example.
I dived in and put my Capacitor reformer on and immediately it came up with a false alarm. I found a potential divider that would account for it and once I allowed for that we were on the Variac.
It was the potential divider going from R24 to ground biasing V5 that did it.
I soon had it up to full power and everything works but with some work to do as there is clipping on the carrier signal even with the correct termination resistor.
I then went for the cap reformer and lowered the limiting resistor to below 1K from 100K and checked most of the grids to see if there was a leaky capacitor in there but came up with no conclusive result.
I have had the scope on V2 and V3 and found that it gets worse around V3.
Next session will be with the X10 probe and the scope on DC to see of the waveform is getting close to the power rail or ground and then look for a biasing problem.
I have two of them to look at so at worst I will have to clear the bench and get the other one open.
Does anyone know what the output connector is called as I only have one and could do with another.
