04-08-2015, 06:40 PM
Recently I had to test a Valve. I did this by using my HV PSU and a couple of Meters, plus wires tacked on to a Base - not very convenient, especially as it was a Triode Pentode. I have a couple of Valve Testers, and a couple of historic ones, but I figured it would be more trouble to get one out and make sure it was doing the right things than knock up a Jig to allow more convenient connections to my PSU etc, and anyway I'd have it for the future.
So, usual Plan, a Drawing first:-
I had a piece of 2mm Aluminium Plate so cut it out and mark up:-
Drill some Pilot Holes and cut out the Corners:-
Cut out the IO Hole - that's the tricky one because I had to do it with a Fly Cutter:-
Seems OK so Drill the other Holes and bend up the Sides:-
Strip off the Plastic and clean up all the Burrs - looking promising:-
To be continued ....
