30-04-2015, 04:57 PM
In a moment of madness I dug out this old A104 set to see if it was worth spending time on.
A quick check showed a rotten rubber mains lead, speaker leads cut, lots of dust, and a completely wrong tuner string set up.
Powered up it produced some noises. A change of THE capacitor restored the correct bias on the UL41 output valve. Then realised that the UBC41 and the UF41 had been swapped round! Put right, it works!
Even the UL41 is OK.
Removing the speaker and support panel which also carries the tuning scale glass and frame I realised that the front fret was a strange perforated gold plastic moulding which is too small all round for the rebate in the cabinet front. It looks like something that should be in the front of a transistor radio. I have an early PAM TB60 tranny with similar stuff.
Clearly not original, distorted and a lousy fit, but what should be there?
A look on the Radio Museum site shows a dark fabric looking fret across the whole front.
The question is what it is and what it mounts on, is it speaker fabric and is it backed with a thin wood panel?
If anyone has one of these sets could they let me know please and upload a good 'photo?
Boater Sam.
