Several years ago I built an ESR meter from a design in the now defunct ‘Television’ magazine, which has given a good account of itself, but I’ve long since lost the copy of the article and PCB artwork.
I decided it was time to make another ESR meter, as I work in a spare bedroom and also an outside workshop, so it’s handy to have two of most items. I looked around for designs on internet, and three ESR Meter circuits caught my eye. The two designs which I considered but rejected were:
This one:
http://ludens.cl/Electron/esr/esr.html
(A transformer to wind, and no PCB layout – built ‘ugly style’)
And this one:
http://www.qsl.net/iz7ath/web/02_bre..._esr/index.htm
(Doesn’t need a transformer, but doesn’t have a PCB – just a circuit).
The one I opted for is at this link. I favoured it because it is built on a PCB, uses easily obtained components, and there’s no transformer to wind:
http://www.members.shaw.ca/swstuff/esrmeter.html
Schematic: http://www.members.shaw.ca/swstuff/esrschematic.png
Original Parts Layout: http://www.members.shaw.ca/swstuff/esrbuildit.png
Original x-ray of parts placement: http://www.members.shaw.ca/swstuff/esrxray.png
Those should be viewed alongside my updated layout and parts placement, showing the changes to the layout. Most parts placements are the same.
I claim no credit for the design, which was the work of VE7IT, but in the sprit of homebrew and experimentation I’ve adapted the original design to my own requirements. I posted my own version on another forum in May 2010, not expecting the interest that it generated – 45 replies and more than 7,000 viewings. Over time, based of feedback I’ve received, I’ve made further modifications and refinements to make the project easier for others to build. For example, the original instructions were vague as to how to wire the zero adjustment pot and the meter. The only reason to have the zero adjustment pot on the front panel was to adjust the meter for full scale deflection as the battery voltage gradually ran down. Because I incorporated a fixed 5V+ regulator, this pot can be a preset one mounted on the PCB, so I modified the PCB layout accordingly, making wiring-up more straightforward. The meter can be built in a plastic or diecast project box – I housed mine in a little oak box I made, which is 4 inches x 5 inches, and 2 inches deep.
Some constructors weren’t sure how to wire an LED to warn that the meter was switched on. I therefore added a series limiting LED resistor and two pins on the PCB to supply an LED.
There are only 8 off-board connections:
meter +/-;
cap test leads;
9V +/- battery leads (via a switch);
LED.
The only off-board items needed for the latest PCB layout are an on/off switch, an LED (which can be omitted if desired), a battery, the meter movement, and the test leads. I’ve attached the latest PCB artwork, and an x-ray of the PCB showing the updated layout with the changes made. All other component placements that I’ve not mentioned on that updated PCB layout, (capacitors, resistors, diodes) are as per the original layout, and to make any sense, the original and updated layouts and the original circuit must be studied alongside each other. I’ve also attached some pics of the completed PCB, and how it’s mounted inside the case.
The layout isn't critical, and can be built on plain matrix boad rather than a PCB if desired, by following the lines of the PCB, wiring components beneath the matrix board.
In this posting I’ve just covered the key points, but I’ll put out a more detailed post, so that anyone who reads this and is sufficiently interested to want to make the project has got more information on how it works, the component list, troubleshooting tips, calibrating the meter, scope traces, etc.
Hope that’s of interest.
David
This one:
And this one:
meter +/-;
cap test leads;
LED.
David
