06-10-2023, 04:17 PM
(05-10-2023, 09:29 PM)Murphyv310 Wrote: I tried a 100 ohm dummy load and it turned fine, so most likely his antenna was the problem and too far out for the internal AMU to pull in, the radio is fine as far as I'm concerned.Almost all internal ATUs are more limited and certainly you can have something no regular ATU will match on a particular band.
I got a VNA that goes to a couple of GHz. Takes a bit of learning how to drive it for different things, but invaluable for adjusting any aerial or finding a 1/4 wave on particular coax at a particular frequency. Moving a pin / needle back & forth as a short at the 1/4 wave distance with open end soldered to an SMA socket, short barrel to connect to analyser.
The FT818ND doesn't take up much space. A bag or case with carry strap and accessories and rather lighter than the FTdx10 to take out. Why not keep it? Get an Elecraft T1 and a CB telescoping base like silver stick and remove coil in side base. Work in a layby with it mounted on car towing eye. Or walking with quad band 2m/70cm/6m/10m car whip on back with a trailing 2.5m wire as a counterpoise.
