06-10-2013, 03:59 PM
Just found this in my loft - I bought it in the 1970s - was a good PSU in its day. Needs a restore and clean up - bit of noise on it - some "over heating" marks on the PCB
I'll start by re-capping it and move on from there... also needs a flexible/sprung new handle - 5 inch fixing hole centres - any ideas for a good supplier? You can see the type required in the photo below - it goes flat against the case.
Found the service manual which may be useful for others as it includes the schematic for all the Farnell E30 models...
Looking at the spec, even by today's standards, it's not half bad
HTH
Edit: Manual is available in The Archive: https://golbornevintageradio.co.uk/forum...p?tid=3770
HTH
sıʌǝɹq ɐʇıʌ `ɐƃuol sɹɐ
ʞɔıu
ʞɔıu
