20-07-2013, 07:54 AM
My concern is that the Reservoir/Soothing Capacitor -not the original, but an RS type fitted elsewhere at some time - is only rated at 350vDC(working)-the surge voltage isn't stated. During testing & repair I measures (a) the mains voltage in my workshop (245v), and (b) the surge at switch on (over 400vDC )
both measured with an analogue meter. Whilst the radio has been running OK
elsewhere, should I replace the can with a 500v type?
Relevant to the above, the main HT measures 320vDC after the initial surge, etc. EL84 valves are used as output devices, Is such a voltage OK for these?
