If I have a conventional superhet with an IF of 465 kHz and I wish to check the alignment of the complete IF amplifier using the 'wobbulator' technique - a ramp-modulated FM signal with the ramp synchronised to the 'scope timebase - what is a sensible range of sweep times / frequencies to choose for this task? And if I am examining only one IF stage, what times / freqs. should I choose for that exercise?
Thanks for your thoughts.
Al. / Skywave.
Al. / Skywave.
, further investigations have revealed that I was being led up the electronic garden path and consequently became confused. I had carried out the initial experiments using an IFT can from the 'junk box'. It proudly stated '465 kc.' on its case; it was lying! :@ Subsequent elementary measurements established that it was, in actual point of fact, a 1.6 MHz IFT !
