24-10-2012, 10:45 AM
For some time now I,ve been collecting parts for a stereo 100w valve amp. Why? I have a few 807 valves, a couple of hefty rectifier valves as well as a very big Partridge mains transformer- but its not HT only 20v @ 10A.(Possible voltage doubler/tripler PSU? And I figure with a bit of help it will be fun and a learning experience. This was inspired by the Williamson amp and an on line conversation I had with Tri comp over on another channel-in that the power of the Williamson amp is a bit puny. So something like the above with a high anode voltage and maybe using four 807,s in P/P per channel but not driven hard,as the OP valves,with either 6N7 or ECC triodes in the pre stage. I,m wary of using a EF86 pentode as I,ve had problems in the past with them.
I,ve looked at hundreds of 807/6L6/KT66 etc schematics,as well as lots of silly American amps with custard yellow/with gold fleck paint jobs. The nearest I,ve come for a basis is the Geloso G727A which uses a pair of 807,s in push/pull for output,but I find the amplifier overly complex in its pre amp stages and it has far too many I/O's.
I want to build something relatively simple, that can amplify a MM cartridge or line level source.With as little distortion as possible,so it,ll need to use FB. Just trying to bounce a few ideas around,Andy.
